Iphone 5S on a Toyota W58810 cd/radio
  • hello,
    plug in the headphone output from the I-Phone purely the adapter cable from XCarLink and connect it to the AUX port of XCarLink, otherwise it does not work with the XCarLink. To the USB port of XCarLink you can only connect a USB stick.
  • Hello Stefan,
    Thanks for reply.
    I want to play music over an usb port because it charges my iphone at the same time.
    What do I need to make this work, besides an XCarLink?
  • Servus,
    you're in the cigarette lighter / power socket in the a charger for your iphone and connect the headphone output from the iphone with the cable for XCarLink AUX port. So it should work that you load the iphone via USB and also hear about the XCarLink music. Idenfalls I think that way.
  • spotifyyatour
    ytmo6toy2
    Iphone 5s
    Hello
    I bought the YATOUR ytm06 toy2 with the following cable.
    http://cntopperstar.en.made-in…or-Apple-iPhone-5s-5.html
    I use this cabel because I would like to play music and charching the battery .
    I use this cable to connect the iPhone to both music playing music and recharge.
    The connection of the YATOUR on the radio is no problem.
    Issues:
    When I play spotify on my iphone 5s and connect with the cable usb and jackplug, I hear no sound.
    When I play on spotify iphone 5s and I only use the jack I hear music through the speakers of the car.
    I can also control the volume using steering wheel.
    The search for a particular song fails.
    This I can do only through the iPhone.
    How can I solve this problem.
    Hier mal für alle blitzschnell übersetzt:
    (ich (Ottili) habe das mal für euch gemacht)
    hallo
    Ich kaufte das YATOUR ytm06 toy2 mit folgendem Kabel.
    cntopperstar.en.made-in-China. ... oder Apple-iPhone-5-5.html
    Ich benutze dieses Kabel, weil ich habe Lust auf Musik und charching die Batterie zu spielen.
    Ich benutze dieses Kabel, um das iPhone sowohl Musik spielt Musik und laden zu verbinden.
    Die Verbindung des YATOUR im Radio ist kein Problem.
    Probleme:
    Wenn ich spiele Spotify auf meinem iPhone 5s und verbinden Sie mit dem Kabel und USB-Klinkenstecker, höre ich keinen Ton.
    Wenn ich spiele auf Spotify iphone 5s und ich verwende nur die Buchse höre ich Musik über die Lautsprecher des Autos.
    Ich kann auch die Lautstärke mit Lenkrad.
    Die Suche nach einem bestimmten Song nicht.
    Das kann ich nur über die iPhone tun.
    Wie kann ich dieses Problem lösen.
    2 Mal editiert, zuletzt von Ottili ()
  • Hast du vllt mal bei Apple angefragt? Wäre jetzt meine erste Idee
    Zitat
    "Der Führerschein berechtigt zur Umweltverschmutzung."
